Heat Pump Federation
Menu
CIBSE HPF HPA
Groundwater Source Heat Pumps
Code of Practice
CIBSE, HPF and the HPA are publishing a code of practice for Open Loop Groundwater Source Heat Pumps.
The Code of Practice, which is being produced by a steering committee with lead authorship from Nic Wincott and Jen Billings of the HPC, will be available from www.cibse.org/CP3.
To get the full benefit of a GSHP installation or a GWSHP you will need to employ someone with design and installation experience. A groundwater source heat pump, like a ground source heat pump, may not perform well unless it is incorporated in a good design by someone who understands the needs of the building, the use to which the building is being put and the local geology.
To ensure a "soft landing" you should ensure that a ground source system is well understood and well maintained and this may include fine tuning the controls in the first years of operation.
SWSHP Authors
Nic Wincott and Jen Billings, the principal authors of the Surface Water Heat Pump Code of practice, at the launch of CP2 at Kingston upon Thames on 20 April 2016.
Menu
