Heat Pump Federation
Menu
Shallow Ground Source Standard
The third Standard to be published is the Shallow Ground Source Standard which covers Horizontal Ground Heat Exchangers: Design, Installation & Materials Standards under the following headings:
The HPF Shallow Ground Source Standard is available to be bought from CIBSE.
If you are a member of the HPF we can send you a copy of the Shallow Ground Source Standard if you: click here.
Menu
