Heat Pump Federation
Menu
Vertical Borehole Standard
The first Standard to be published was the Vertical Borehole Standard which covers Closed Loop Vertical Borehole: Design, Installation & Materials Standards under the following headings:
The HPF Vertical Borehole Standard is available to be bought from CIBSE.
If you are a member of the HPF we can send you a copy of the Vertical Borehole Standard if you: click here.
Menu
