Heat Pump Federation
Menu
Thermal Pile Standard
The second Standard to be published is the Thermal Pile Standard which covers Thermal Pile Standards: Design, Installation & Materials Standards for thermal pile ground heat exchangers under the following headings:
The HPF Thermal Pile Standard is available to be bought from CIBSE.
If you are a member of the HPF we can send you a copy of the Thermal Pile Standard if you: click here.
Menu
